22 พฤศจิกายน 2026, 04:32:11
:::CIVIC CLUB THAILAND:::  |  คุยคุ้ย Civic  |  Civic Club Car Knowledge => คลังความรู้คู่รถ  |  หัวข้อ: Japan car's accessories regulation 0 สมาชิก และ 1 บุคคลทั่วไป กำลังดูหัวข้อนี้
ผู้เขียน หัวข้อ: Japan car's accessories regulation  (อ่าน 4804 ครั้ง)
Bicycle
กระทู้: 101
Honda Dream
« เมื่อ: 26 เมษายน 2007, 19:05:00 »
Exterior
- Tailpipes : Tailpipes are not allowed to protrude past the car's body ,however tailpipes that are built into the side of the vehicle are allowed
- Body kits /Aero parts : Aerodynamic mirrors,windage trays under the tail section of the car and body kits using front bumper scoops are allowed.However all aerodynamic parts must fit and molded correctly so they flush with the car's body
- Fenders and Overfenders : All fenders and overfenders (includeing widebody style-kits) mush not inhibit the turning of the car's wheels.
Speedometer
- The speedometer of the car will be tested by driving up to a dynamometer.The vehicle will be propeled to 40 km/h twice and the vehicle's engine rev amount will be recorded, should the vehicle have difference numbers it will not pass.
Headlight
- All headlights must be aligned to be in a straight line with their height on the car.
- All headlights must have the same color when turned on.
Exhaust/Muffer
- Cars that are 10 years and newer must have carbon monoxide measurements of 1% and hydro-carbon output of 300 ppm.
  Cars older than 10 years must have carbon monoxide measures 4.5% and hydro-carbon output of 1200 ppm.
- High flow catalytic converters are allowed however gutted ones are not.All O2 sensors must be in working order along with any oil catch tanks.
- Muffers when tested for noise output will be tested at a 45 degree angle at a 50 cm. distance.
  - For verhicle 10 years and younger the max level alowed is 96 dB.
  - For vehicles over 10 years of age the max level allowed is 103 dB.
Suspension
- The vehicle must meet minimum height requirements,
  - For vehicles with 200-249 cm. wheelbase they must be 8 cm. off the ground .
  - For vehicles with 250-299 cm. wheelbase they must be 9 cm. off the ground.
  - For all other vehicle for every 50 cm. over 299 cm. in wheelbase add 5 cm. to the minimum height .
  - For vehicles under 200 cm. in wheelbase subtract 5 cm. to the minimum height.
Interior
- General interior equipment must be still intact (ie : dash)
- Rollcages (must have padding around bars) and carpet removal are allowed.
- Aftermarket seats made of fiber-reinforced plastic are not allowed.Any holes or rips in seats must either be taped up or repaired.
 อายจัง อายจัง   (เดี๋ยวมาแปลให้ฟังอีกที อิอิ )  ยิงฟันยิ้ม
« แก้ไขครั้งสุดท้าย: 02 พฤษภาคม 2007, 18:07:29 โดย Bicycle » บันทึกการเข้า
zhaonenghe
ตี๋
กระทู้: 619
« ตอบ #1 เมื่อ: 27 เมษายน 2007, 23:11:32 »
เกี่ยวกับรถป่าวหว่า  อ่านไม่ออก
pReaw
Francesco Pevi.
กระทู้: 519
http://parpreaw.multiply.com
« ตอบ #2 เมื่อ: 23 มิถุนายน 2007, 16:41:58 »
รออยู่นะคับ :'(
--->civicclub no.204<---
